1 - 8 of 8 Posts
OK I know the bulbs are H11s. I want to replace them with something stronger but I dont see the best way to get at the back of the lights to change the bulbs. Which is the best way in?
Thanks in advance.
What replacement bulb are you going to put in.
Turn your tire in on the one that your doing and reach right down in there to change it.
Ok Im an idiot. cant believe it is that easy.....duh... must be all the paint fumes i been smiffing today.
PIAA yellows
PIAA yellows
you got a pic? i have a 2010 SE 4x4 CC, Knight Armour that i want to add fogs too... do you have pics in daylight and night so i can see what it will loook like?
thanks!
thanks!
When off...they are clear... here is a pic of them on
By the way... when finally got to it.. this way did not work. The wheel well are entirely encased in a plastic tub. But it was still easy. There are 2 screws to the tub under the front bumper. Once removed you can pull the plastic away to get one hand in there and do the change by feel.
1 - 8 of 8 Posts
