1 - 8 of 8 Posts
Sorry if this has already been asked, and i'm just being a no0b, but i've searched a bit to no avail.
The underdrive crank pulleys that are made for the 240sx ka24de, will they fit our ka24? also, there are sets of 4 which include crank, power steering, etc....are they the same in the 240sx as in the frontier, or vastly different?
thanks in advance.
Wow I have been trying to find an underdrive pully set for my motor as well. I have the 01 2.4 motor. I have been looking and all I have found is sets for the 3.3L. I would like to know if they would work to
I am not sure if anyone has actually done this but you may want to look at the stock pulley and the UD one. I know the 350z (VQ35) pulleys will not work on the Frontiers (VQ40) because the z uses 2 belts over the Fronter's 1. This would give you a quick check. If it works out, then move onto step 2 and start looking at PNs between the KA24 pulleys per platform (frontier, 240sx, etc...). If they match, then it should be a go. If they don't, then more research would probably be needed. Heck, maybe just order the pulley and try it, if it works then great, if not, then just return it.
Discussion Starter #4
I thought about ordering the 4 pulley set for around 175, and if all else fails, just resale on craigslist or nicoclub or something.
But you bring up a good point about comparing part numbers for the stock parts....it shouldnt be too far off....it's gotta be basically the same engine, except for the intake AFAIK.
Good idea man I think ill try that cause they hafta somewhat be close anyhow I mean a 2.4 is a 2.4 just diff configurations...
Discussion Starter #6
Mods;
any ay you guys could move this to performance mods, so i'm not starting a new thread with same topic over there? Maybe the guys over there have a bit more input on this issue.
I am guessing that you havn't gotten a lot of posts since most 1st gens with the 4 bangers have accepted that its not built for speed but for chugging along for hundred of thousands of miles. I have only seen the 2nd gen 4 bangers and 6s swap pulleys.
Also, for the statement that a 2.4 is a 2.4, that isn't exactly true. Most likely they have the same pulley shaft diameter but they may have a different length or belt set-up.
Discussion Starter #8
i've seen 300+ hp ka24de's before....in the 240sx of course, but same platform afaik. the two engine applications can't be so far off that the upgrades aren't at least very similar.
not that i'm going for a crazy performance engine here, just looking for some simple upgrades and going from there.
1 - 8 of 8 Posts
