Hows it going, bought an 01 frontier in september and loving it. But there are some issues with it.
1)When i bought the truck it had a slight pull to the right. The tires were pretty worn and the dealer said that was the problem(they had re-balanced rotated and re-aligned it). I went and got some new tires on the weekend, but its still pulling to the right (even worse since the tires arent worn the same). I went to get it aligned again but the mechanic explained it wasnt possible because the chamber bolt was seized and that i would probably need a new control arm. What do you think?
2) The service engine soon light is on. I thought maybe for the exhaust, but when the tires were being changed i got under the truck and noticed the gas tank was leaking from the top. I couldnt tell from where. Wondering if anybody else has had the same problem.
thanks Matt
thanks Matt
