1 - 2 of 2 Posts
2001 SE V6 crew cab manual transmission 95k miles
sometimes the truck runs solid. Sometimes like today, It starts up fine I drive it about 2 blocks then while waiting to make a turn truck in neutral for about 3 mins it just dies. I start it and it doesn't happen again. Sometimes it takes me to work and when I reverse into the spot it dies, It always turns back on with no problems.
There's not really enough information to tell you what your problem is. I would check to see if your vehicle is due for a tune-up...then, I would check the base idle setting per the service manual procedure and adjust as necessary. Also, check for split or leaking vacuum hoses. If that doesn't help, check the IACV/AAC valve to make sure it is operating properly; this is what controls the fast idle and also maintains base idle by compensating for engine loads.
1 - 2 of 2 Posts
