1 - 10 of 10 Posts
2012 Pro-4x / 97k: had to stop on a decent uphill slope. When the light turned green I gave her gas and she wouldn’t move. I could feel the truck try to move but it was like something was locked up. Did it again a couple minutes later on the same hill, same scenario. Is the tranny on its way out? What should I check? All oils were replaced only 7k ago
Are you sure its not the hill assist? The brakes will hold you on a hill to keep you from rolling back until enough acceleration is applied then it releases. Mine is not always consistent, sometimes it holds it harder than others.
It could be, I don’t know what “activates” to keep the vehicle from rolling back. After topping off the oil, I tried to replicate it but it acted fine
When you let off the brakes after coming to a complete stop the vehicle keeps the brakes engaged until you apply enough gas to break it loose. I find that mine is inconsistent sometimes and i will need more gas than other times to overcome the brakes.
Thanks for the humbling moment. I checked it with the engine off and it was way high. Then checked again with the engine running and it is low. Guess this is a check done with the engine running.
The trans fluid should be checked with engine running, trans in park or neutral and up to operating temp (there is a lot of fluid in there so thermal expansion matters).
Too high is very bad for auto trans also! Don’t go over the max mark.
1 - 10 of 10 Posts
