Last night my brake lights where stuck on....looked inside and found a broken rubber nipple on floor of drivers side....It hits the switch to turn off brake lights. Grabbed wire harness and unplugged till stores are open and got light.
So....in the past I have fixed this with just a small nut and bolt...but room is limited in this repair and it is tight for guys with large hands , so I went to Nissan paid $11.35 for the new nipple , now black not the original tan color and put it in...
I suggest you use needle nose and double sided tape unless you got small hands,
tape nipple to needle nose , have wife or kid press down brake lever , reach under and line it up with hole and squeeze.... and TADA....done deal brake lights fixed....
OK I know its not a gnarly walk through , but in case someone else less mechanically inclined runs into to it....its there...
