1 - 11 of 11 Posts
A few weeks ago I took my truck in to have the dealer perform fluid service on the transmission, both differentials and the transfer case. They found a leaking rear axle seal. Surprise!! And only 51K miles on the truck. They fixed it under warranty. The experience got me to thinking I ought to do the axle vent mod described in several forum threads.
I bought the parts last week and today I went to install it. The hose barb I bought does not fit the axle. It is real close, but just won't go. Does anyone have a part number from Amazon or Home Depot or ??? for the barb?
The part I bought is from Amazon. One of the forum threads says the threaded end is 1/8 inch NPTF. I could not find any such thing, so I went with 1/8 inch PTF. What is the difference?
That same thread has a Toyota part number, but I could find no references to it and no place to buy it.
When I took out the existing vent, I saw some cruft in the end. It looks a bit like a sponge that has been soaked in oil. The cap on top is loose and spins easily, so I figure it cannot be too badly plugged.
I see most axle vents are done with a straight barb. I want to use a right-angle because I think it will be a bit easier to make a coil in the hose to allow axle movement, and also a bit easier to route the hose up and over the exhaust. I don't want to tie the host to the brake line.
Thanks - Bill Gee
This is the one I used... Put a little teflon anti-seize tape on it and it threaded right in.
It doesn't solve your 90 degree request, but I can't say I've ever seen one that wasn't straight...
Geekmyride - Thanks! I'll take this to the dealer and see what they have.
Chris_B - An interesting idea. I probably won't do it because it leaves me no go-back option. I see that OEM breathers with caps can be had on eBay for $11.00. If I can't find a true barb, then Plan B is to buy a new OEM part for backup, "modify" the existing part and see what happens.
Bill Gee
Read the sticky on the topic. I have discovered that it is not NPT or NPTF. I think it is the british variety which is 28 tpi. I have some fittibg coming in the mail. Get the nissan part. Known to fit.
My nissan dealer gave me the part, so they wouldn't have to worry about doing axle seals on my truck
Axle breather mode done - With photos
Hello everyone -
Thanks for the suggestions. I tried buying the adapter at the local Nissan dealer, but they did not have it in stock. Since I had to order it anyway, I went online and got it from https://www.courtesyparts.com. Shipping was rather high for so small a part, but they shipped fast.
It took less than an hour to install. Photos attached. I won't give any detailed instructions because others have taken care of that. The only thing I did different was to NOT attach the breather line to the brake line. I did not want to put any additional stress, however little it might be, on so critical a part.
Bill Gee
Not NPT
It is BPT
Not National but British threads. Thread pitch is a little different. If you jam a NPT into the hole the threads will bind before a seal is made.
The oil pressure sender is also BPT and why they tend to leak when someone gets a NPT oil pressure fitting trying to jam into the hole.
i got an OE replacement, but will be checkin out opening up the end + adding a hose, simple + cheap!!! E-bay almost always ships FREE!!!
just changed my rusty vent yesterday, + pulling it apart reveals a light spring + a small round gasket with a VERY short end unsuitable to clamp a hose on. so i will be getting the fitting listed for Taco's + adding some hose + filter, cheap + easy!!! i had an open hose by the factory air box + noticed it went to the front diff so i zipped it + added a filter there. good stuff + thanks to all for the info!!!
1 - 11 of 11 Posts
