1 - 3 of 3 Posts
hello everyone,
just got my prg ucas in mail and have one question regarding installation:
Do i have to adjust the bolts that are located between the UCA and the UCA mounts? I'm not sure about the proper terms in m question so I included the picture to clarify myself.
Thank you
BTW I will be running radflos 2.0 w/ 650lb spring if that matters at all. (no spacers)
This adj is for the dude at the alignment shop. There is no way to know where to set them prior to the install. I am 95% sure thats whats it for. If im wrong Im sure someone will correct me.
You are correct, these can be used to help dial-in the alignment.
What I would advise is to not have them start with basic alingment cranked all the way to one side and then go the last bit with the hiem joints. Rather, if you can get the truck setup with some adjustment in either direction, then they won't have to adjust the hiem joint for each subsequent alingment. Otherwise the shop will quickly learn to hate aligning your truck since the only way to adjust the length of the heim joints is to disconect them.
1 - 3 of 3 Posts
