1 - 15 of 15 Posts
I am going with a completely custom race kit and would like to offer my old set up to anyone interested.
What I have for sale...
PRG Upper and Lower Arms - 5.5" over stock
- Will include heimed steering, ball joints, and all hardware w/ uniballs and heims
CST 4" lift spindle with hardware
2.5" Sway Away 8" stroke coilover with 600lb spring rate, external reservoir, and valved specifically for a 2wd Frontier.
Shock hoops w/engine brace - I will cut everything very cleanly, but this will still require some fabrication to install properly and must be used with an 8" SwayAway or 6" shock of any other brand.
Feel free to ask any questions and if you are in San Diego you can come for a ride in the truck to see how it handles before purchasing. Anyone that has ridden with me can attest to how smooth my truck works....
Control arms, shocks are my main goal. steering would be a plus. But i would like to fab shock hoops and cage unless youd highly recommend against it which im sure you will. PM me what you looking to get for it.
PM sent...and I would like to address the hoop question here, being I could easily see others asking themselves the same thing.
My personal opinion...I think the best option would be to take everything to a reputable fabricator and have them install the arms and steering and have them build you hoops based on how they cycle the kit and where they feel the shocks should be mounted on your truck.
However; that can be very costly and my set up is a proven design that I and others know works very well...your custom set up will only work as well as the fabricator building it for you. And no matter which you choose, you will still need to measure/cycle/measure/tack/cycle/measure/cycle..etc to have my hoops mounted to your truck.
So no matter how you look at it, this will require some fabrication. If you have the means, than I would take the first route and have everything set up specifically for your truck. If not, this is a real cheap alternative to run the longer shock.
This is when I wish I had money :(
Ohh Sh!+... here we go with another project thats gonna make me wish i was rich.. haha.. damn i need 2 deploy again and just go all out instead of messing around with lil things here and there.
**Bump** For Jay's Set-up!
PM me for the Shock hoops w/engine brace and your recommended fab shop (the one you did it at...) and how much it would cost me to install. I know you'd just have a ballpark....
NM... I just PM'd YOU... I have more Q's.
1 - 15 of 15 Posts
