1 - 11 of 11 Posts
I got the prg advanced extended coilover lift kit. The coilover is longer than stock shock, and i cant get it to fit. I get the 3 bolts up top in and aligned, but when i try for the bottom of the strut the hole is like 1/2 inch away from being aligned to put bolt through. Ive tried prying up with a bar but still cant get it up enough to stick bolt in. Any help would be greatly appreciated. Thanks
I tried but couldnt get the spindle to seperate any tricks there?
Get a hammer, and smack the ball joint, it will eventually pop and break free from the upper control arm. Hit it where the red arrow is pointing below, and dont be a girl about it, youd need a pretty big hammer to do any sort of damage.
My passenger one came undone with a couple good whacks from a 1.5lb engineering hammer. The left I had to beat from the bottom, but since I put SPC UCAs on, I wasn't worried about damaging the stock parts. Just did it Saturday. You'll love how it rides.
1 - 11 of 11 Posts
