1 - 10 of 10 Posts
I have the PRG 4wd Advanced Coilover Lift - PRG Products and BFG 255 85 16 KM2s. When i turn, the front tires rub a little. The next thing on my list is the Shrockworks bumper, which will probably make the front end sit lower with the added weight.
I wanted a body lift, but its alot of work. So will the PRG Front Lift Spacers - PRG Products - work with the Adv Coilover Lift? How strong will it be? I use the truck as a daily driver, but I also dont want it to break off road. Will I loose wheel travel?
Can I add the Variable Height Frontier Shackles - PRG Products - to keep the rear level with the Deaver 2-Leaf Spring Packs already on?
How much are they rubbing and where. If its anywhere on the plastic fender liner you can just take a heat gun and heat it up. Then take a damp rag and bend it back and let it cool off. I just did this a couple of times to mine to get the plastic to take a different shape. But I was still rubbing in other spots and had to trim some. But you can melt back that fender lining no problem.
thanks, ill call greg and see if he can make a 1" spacer that will work so i will have the extra room. ill try the heat gun too. they rub on the front side under the fender sometimes when i turn. i had a wreck a couple of weeks ago which made them seem to rub even more. guy in front of me slammed on his brakes and i rearended him. just appeared to scratch my bumper, but the tires were rubbing more.
no, ive been waiting to get the new bumper so i havent tried to remove anything. got a wife who thinks $950 + $1000 for a winch is too expensive. i remember having alot more truck parts when i was single.
^ yah x2. that was the first thing i ripped of my truck with my xe plastic bumper. made it look a lot better.
Greg said he could make a 1" spacer that would work with the Radflo's, but not stock coilovers, but it would take away wheel travel. he also said i can adjust the coilovers, but then it would ride rougher. he said the next option is a drop bracket lift.
since its a DD, i guess ill be doing some cutting or go find a heat gun.
1 - 10 of 10 Posts
