1 - 4 of 4 Posts
Hi all, looking to do a small lift on my 2012 PRO4X. I'm looking at the PRG 5100 SAAL kit. My truck is a daily driver and may see some light trails on occasion. I'm looking for something that won't break the bank and may give a little better ride. This is the kit I, thinking about:
PRG Products
I would also go ahead and add some Bilstein shocks to the rear as well. Anything else I would need with this lift? How is the ride quality, any first hand experiences? Thanks in advance.
I did that same lift on my frontier. My fronts are at the highest setting and I ended up adding the bilstein 5125 shocks for 2"-3" lift and I love the setup! Stiffer up front at the highest setting but you could set it lower, I like the ride. Rear shocks were a surprisingly huge improvement.
So did you end up getting this kit? I also have a '12 pro-4x that I'm considering getting this same product. Do you like it? Do you have pictures?
You seriously can't go wrong with the 5100s. Remember the higher the setting the stiffer the ride. Grab yourself some 5125s from PRG. Those are legit.
1 - 4 of 4 Posts
