Here's the issue, when unlocking via the remote or switch on the door the locks just click but don't move. It just started today and affects all doors, any idea's are appreciated.
What I've done so far,
1. The drivers door will unlock and lock via the remote but the switches inside only cause a small click to occur.
2. I removed the door panel and disconnected the switch and used the remote to cycle the lock and only the drivers door responds properly, the others just make a click noise.
3. I looked down inside the door with a light and found no evidence of water.
P.S. I found a strange situation... if I press the unlock or lock on the door more than a few times the windows stop working and the switch makes an awful buzzing noise until I take the key out.
Do the windows and door locks function through the BCM? I'm leaning to the possibility that it's going out. Another strange issue that popped up is the passenger heated seat if switched on with blow the fuse, even with all the wires to the seat unplugged.... still not quite sure what to make of this... Heated seats a BCM thing also?
