4701 - 4715 of 4715 Posts
Its a 2wd. 4"CST spindles plus half inch spacer. 2 inch blocks. 285/75/16 Goodyear Duratracs which are supposed to be 33.1 inch tall. Most 285's are 32.7 inch.
Specs on your tires:
The 285/75R16 Goodyear Wrangler DuraTrac has a diameter of 33.1", a width of 11.3", mounts on a 16" rim and has
637 revolutions per mile. It weighs 54 lbs, has a max load of 3750 lbs, a maximum air pressure of 80 psi, a tread depth of 18/32" and should be used on a rim width of 7.5-9".
Trucks doing what trucks do best. Truck things. 7900# combined rig, 4 axles, 7 states, 632 miles, 13 hours in one day. What a ride. Saturday 19 October.
309896
309897
309898
2019 pro 4x with tonneau cover,arb steel bumper and 2.5 leveling kit.next step is to try and lift it but nothing seems to be available for the pro 4 as far as lift kits go looks like my only option might be a titan swap to get it a little higher anyone have info on it would a titan swap have the desired affect and would I be able to install a lift kit along with the swap
310085
2019 pro 4x with tonneau cover,arb steel bumper and 2.5 leveling kit.next step is to try and lift it but nothing seems to be available for the pro 4 as far as lift kits go looks like my only option might be a titan swap to get it a little higher anyone have info on it would a titan swap have the desired affect and would I be able to install a lift kit along with the swap View attachment 310085
any lift for the frontier of that year will work for yours.
How do you like that bumper?
