1 - 4 of 4 Posts
My 06 Nismo has the upgraded audio system with the 6 CD changer. The AM reception is very poor. Stations that can be heard very clearly with any radio are a weak garbled mess in the Frontier. However, its FM reception i excellent. So it seems, the antenna is not at fault.
Does anyone have any ideas on the cause?
Since AM and FM are on two different bands the antenna can still be at fault.
Unscrew the antenna and look to see if there is any corrosion on the bottom. If there is a light sanding will clean it. What have you got to lose by looking.
1 - 4 of 4 Posts
