1 - 3 of 3 Posts
After Some research ive came to the conclusion that i might do this setup:
1.Prg-upper control arms
2.prg radflo 2.0 coilovers (are they any good, and can i find some bigger than the 2.0 but without needing lower control arms?)
3. I cant find where to get them but i want to get 1.5' deaver rear leaf springs.
4.Bf Goodrich all-terrain t/a ko (lt215/75r15)..(whats the biggest i can go withouth rubbing)
5. Pro-comp 52 rims 15x7..6 on a 4.5( whats the biggest that will fit without rubbing on these things)..On a side note no fake beads for me its all real or nothing..since im not goin to crazy with this thing i think these will be ok.
6. if needed hannemann fiberglass..
I want feedback and tips if you do not mind.. Shoot me in the right direction.
for #6, you shouldnt need the glass unless you go with a titan swap/mid/long travel set up.
Im assuming that you have a 2nd gen (2005 and up) you deffenantly cant go wrong with PRG.
...I want feedback and tips if you do not mind.. Shoot me in the right direction.
^ Call PRG.
Be patient(might be busy moving to NorCal :)).
1 - 3 of 3 Posts
