1 - 7 of 7 Posts
Looking to tow my Fishing Boat , I have seen the plug-in harness at auto stores but they only show up to 2003. Will this work or is there a change for the 05-06? I have an 06 SE
No, you to get the factory harness that comes with 2 relays
i bought the factory harness for 30 quid (50 bucks??) - no relays. easy to install. NOT the same as he pathfinder (differnt plugs for some reason).
HTH
Guy
Towing wire harness
I just installed the OEM flat 4 wireing harness - it comes with a couple of relays that install in the pas. side cab bottom right - with the pig tail that plugs into the back with a nice mounting bracket. Recommend you get this one. Got mine at Courtesy Parts for $46.55 + shipping. You have to specify manual shift or automatic - the reqirement for the relays are different.
Or 3 relays i don't remember which one takes 3, i think the auto takes 2 and the manual takes 3
do you have to run any wires up under the hood??? i heard this from someone and was cerious
There is about a foot long harness for the relays.I'm not sure where it goes since mine came with the tow package.I did buy a 4 pin harness kit and tapped it into my 7 pin harness.It came with 3 relays,relay harness,traiker harness,mounting bracket and hardware.
1 - 7 of 7 Posts
