1 - 3 of 3 Posts
I have an 04 fronty 2wd 4cyl and wanting to lift it 3 inches. i was first looking at the body lift but didn't want the chassis showing anymore than it does. I'm now considering the suspension lift from AC...new upper control arms and I think adjust the torsion bars with add a leafs in the back which will give me 2.5"....how much should I adjust the stock torsion bars to make it level with the 2.5" the add a leafs will give me in the back?? and al so heres the link to the front suspension components...is this alll i will need? and all I have to do is adjust the torsion bars after i install the new upper control arms?
https://www.4x4parts.com/nissan/fron...lift-p-84.html
with new arms you can go up to 3" you will just have to adjust and check adjust and check to see when you have the bars level. and yes all you would need to do is adjust the bars. then go get it aligned
1 - 3 of 3 Posts
