im getting my system together and i see alot of guys using these. I plan on doing 3-8"s. Any input on these subs??
yeah with the first amp... the second one doesn't have enough power, should work ok, just hook the positive from the amp to the first sub's positive, then the neg to the next sub's positive, then the neg from that sub to the last sub's positive, then the neg from that one to the amp's neg... make sense?04biggmaxx said:im going to do 3 subs. i thought i should run 2 in series for 8ohms then parallel those 2 with the third at 4ohms for a total of 2.67ohms? your sayin just run all 3 in parallel??
if you want that particular amp( premire ice 1000) then yes, its able to be run as low as 1ohm. if your geting another amp that is only able to be run as low as 2ohm then follow my picture diagram and run it at 2.67ohms.04biggmaxx said:im going to do 3 subs. i thought i should run 2 in series for 8ohms then parallel those 2 with the third at 4ohms for a total of 2.67ohms? your sayin just run all 3 in parallel??
actually no, that would series all the subs for a total of 12 ohms. what he needs to do is series two of the subs then parallel the third. (see my previous diagram)HKYStormFront said:yeah with the first amp... the second one doesn't have enough power, should work ok, just hook the positive from the amp to the first sub's positive, then the neg to the next sub's positive, then the neg from that sub to the last sub's positive, then the neg from that one to the amp's neg... make sense?:wtf:
Why has no one pointed out that one of these subs (the one in the middle) will put out twice as much as the other two? Yuck. I can't imagine the weird sound reproduction you'd get from that setup if you had all 3 subs sharing the same airspace. Having them share airspace is iffy in the base case -- with the subs moving at different velocities, it could create some "interesting" unintended effects.SQnismo said:here this might help
