I'm now an official Auxito lighting corporate partner, use the following link and the coupon code below to get special discount pricing. This will also help me fund purchases for new equipment for the Frontier Geek YouTube channel, your support is greatly appreciated.
AUXITO® Car LED Lights | LED Forward, Interior & Exterior Lighting
Ultimate light beam pattern for your Car LED forward, interior & exterior lighting. See your road more clearly with bright and easy-to-install AUXITO LED bulbs, increasing reaction time and making night driving safer.
Discount Code: BackNow - 20% discount
Discount Code: FrontierGeekAuxito - 15% discount, use this code if BackNow is not accepted.
MooseKnuckle Offroad, the inventor of the split shackle.
Discount Code: FrontierGeek - 10% Discount
MorrFlate Multi-Tire Vehicle Inflator Systems
Discount Code: 5% discount for signing up to email notifications.
So its time to get this build thread started, found out Kyocera smart phones aren't the best camera's in the world, I think I'll start using the DSLR going forward, but anyhow, after the axle vent mod, it was time to get lighting and transmission cooling started.
I have the trans cooling fan mounted now ( thank you Jeg's ) and the LED light bars mounted and temporarily wired.
The cooler fan will have both automated thermostatic and manual override switching via my new relay panel and in-cabin switching bank, still debating going behind the sunglasses holder or the rearmost panel behind the dome lamps.
6 LED backlit switches have arrived from superbrightLEDs.com, pretty similar to the ones others have purchased and/or recommended, but at only $7.99 each, couldn't turn down the savings vs $15.50 to $18.00 each.
Weatherproof LED Rocker Switch with Legend | Super Bright LEDs
Going to build a custom relay/fuse centre that will sit above the factory IPDM E/R and provide safe switching and fusing for the six circuits I'm adding ( 3 for future including 1 for future 52" curved LED roof bar ).
Stats:
2014 Nissan Frontier Pro4x 4x4 with VTP Package
Nickname: Pillar of Autumn ( formerly Silver Surfer )
Updated List of Modifications:
Exterior:
Mini-Push Bar, front
2 x 16" LED FleaBay light bars, AutoPartM
2 x LED "Pod" Lamps - SuperBrightLEDs.com
1 x 42" curved front LED bar
2 x 22" side LED bars
2 x Ditch lamps, on Rago Fabrication fender mounts.
LED Headlamp replacement bulbs, Katana 9007 series 6.5k @12,000 lumens
LED Foglamp replacement bulbs, Hikaris 6.5k @10,000 lumens
LED running / brake lamps - SuperBrightLEDs.com, festoons in red
LED reversing and license plate lamps, CheckItAuto
Duplicolour red ceramic hi-heat paint, brake calipers
Fabtech 3/16" plate steel radiator skid plate w/ oil filter access port, painted red
ShrockWorx rear differential armour, painted red
Hefty Fabworks aluminium bash plates, engine, transmission and transfer case, stock Pro4x fuel tank skid in steel
iArmour lite-duty rocksliders, by APG and shipped through CarID
iArmour rockslider / Side Step 5' LED puddle lamps
Axle vent mods - K&N breather filter front & rear axles, rear vent relocation to behind right taillamp
Curt cargo / luggage basket attached to factory roof rack, with Curt optional length extender
Linkitom 40 LED 12v auxiliary truck taillamps mounted to rear face of Curt cargo basket
Window Vent Visors - AVS
DrawTite Hitch
7 & 4 / 5 pin trailer electric hookup - Tekonsha harness and relay kit, bumper relocation mod, Hopkins connector.
Power rear tailgate lock / unlock solenoid
Home-made rear wheelarch liners, plastic
Ridgid Bed-Mount toolbox 32" jobsite model, 32R-OS with custom installed Lowe's SuperStrut for Nissan cleat tie-down point mountings
Full perimeter LED flexible strip lighting for bed illumination under the tonneau cover
Custom on-board air with ARB compressor, two pressure regulators and red flexible air hose to air up / down
Custom in-bed tool mounts with QwikFists, to hold axe, shovel, hammer, adze and sledgehammer, mounted to OE Nissan UtiliStrut system
Red tuner lug nuts - 24 Pc Set Spline Tuner Lug Nuts ¦ 12x1.25 ¦ Red for Nissan Suzuki | eBay
Titan Wheel Accessories 1.5" hubcentric wheelcentric spacers -
Interior:
Custom overhead console light control bar, SuperBrightLEDs back-lit rocker switches.
LED dome lamps - CheckItAuto
Autometer gauges for transmission and engine coolant temperature
Centre console lid padded leather cover from Poland
Scosche by Nexar NEXS1 smart HD interior dash camera, Sony Starvis image sensor, hardwired.
Powered rear sliding window, Honda Ridgeline drive motor assy and custom aluminium mounting brackets by CF member Harm.
6 fuse hot all times and 6 fuse ignition relay switched power distribution centre on driver's kickpanel , behind instrument cluster & near steering column
Audio & Comms:
Sundown Audio SA-2.75FR neodymium mid-highrange speakers ( factory tweeter locations )
Morel Audio Maximo 6 - 6.5" component set for the doors - Crutchfield.
Yaesu TF8900R 4-band HAM radio & Kenwood external speaker, the internal Yaesu speaker is small and not very distinct.
Engine Bay:
K&N drop-in air filter
Custom-fabricated six circuit control fuse / relay centre controlled by switch panel in Interior details
Jegs 10" 615CFM cooling fan on factory plate & fin transmission cooler ( thermoswitch and manual override controls ).
Front differential breather mod, K&N breather filter added to factory breather tube
Full-width flexible LED strip light for night underhood inspections or repairs
Hood lift struts
Red anodized aluminium oil filler cap - no longer listed on Amazon
Group 31M battery - Advance Auto DieHard
Red silicone radiator hoses from Z1.
HO ignition coils from Z1.
NGK Rhodium spark plugs
Suspension:
Firestone RideRite rear spring overload airbags ( kit# 2558 from AutoAnything ) with Firestone 1/2 gallon steel reserve air tanks plumbed in ( two ). 3 gallon Firestone reserve tank with pressure regulator plumbed to feed both 1/2 gallon snubber tanks through check valves. ARB compressor with 70PSI cuton 100PSI cutoff to feed the 3 gallon reserve tank and a separate pressure regulator and qwik-connect for on-board air line with tire stem chuck.
1.5" Titan Wheel Accessories hub spacers.
Front: Bilstein 6112 coil-overs & tophat spacer lift for about a 2" overall lift. All Dogs Offroad upper control arms to eliminate coil bucket contact ( CBC ).
Rear: Extended comfort-ride rear shackles 4" extension which provides about 2" lift at the wheel hub. Home-brewed spacers to lift the air bag lower mounts 2" to compensate for the shackle lift. Old Man Emu HD shocks.
Moose Knuckle Offroad | Recovery Gear | Inventor of the Split Shackle
Moose Knuckle Offroad Recovery Gear & D-Ring Anchor Tow Shackles for Jeep Wrangler, Gladiator, Toyota, 4x4 truck, lifted trucks and off-road enthusiasts. Our Patented shackles are designed as a functional towing, recovery or pulling accessory that coincidentally looks like truck nuts, bull balls...
moose-knuckle.com
MORRFlate - Off-Road Air Inflation & Deflation Tools & Accessories
4-Way Tire Inflation Tools, Muti-Tire Inflation and Deflation Tools, Off-Road Air Compressors, Shop Tools, Inflation Accessories & More
www.avantlink.com
Stats:
Exterior:
Tri-Row 16"inch 864W LED Light Bar Spot Flood Offroad Driving Fog Lamp 4WD | eBay
Find many great new & used options and get the best deals for Tri-Row 16"inch 864W LED Light Bar Spot Flood Offroad Driving Fog Lamp 4WD at the best online prices at eBay! Free shipping for many products!
www.ebay.com
4
27W Titan series lights contain 12 powerful LEDs in a compact 4” housing. The 30° spot and 60° flood beam patterns can be individually activated or combined for maximum illumination. The IP67 rated waterproof aluminum housing protects against damage from submersion in water while also dustproof...
www.superbrightleds.com
42inch 540W Curved LED Light Bar Tri Row Spot Flood Combo Offroad Driving 7D 4WD | eBay
Find many great new & used options and get the best deals for 42inch 540W Curved LED Light Bar Tri Row Spot Flood Combo Offroad Driving 7D 4WD at the best online prices at eBay! Free shipping for many products!
www.ebay.com
12 inch 120W Led Light Bar Spot Flood OffRoad Fog Light For JEEP FORD | eBay
Find many great new & used options and get the best deals for 12 inch 120W Led Light Bar Spot Flood OffRoad Fog Light For JEEP FORD at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Amazon.com: AUTOFEEL LED Pods Light 4 Inch LED Light Bar 2PCS 80W Spot Light Single Row 8000LM Off Road Driving Fog Lights for Trucks SUV Boat : Automotive
Shop Amazon for AUTOFEEL LED Pods Light 4 Inch LED Light Bar 2PCS 80W Spot Light Single Row 8000LM Off Road Driving Fog Lights for Trucks SUV Boat and find millions of items, delivered faster than ever.
www.amazon.com
Amazon.com: YITAMOTOR 921 LED Reverse Light Bulbs White T15 912 906 LED Replacement Bulb for Backup Lights, 12-24V, Canbus Error Free, 2000 Lumens Super Bright, 360-Degree Shine 90-EX Chipsets 3014 SMD LED : Automotive
Buy YITAMOTOR 921 LED Reverse Light Bulbs White T15 912 906 LED Replacement Bulb for Backup Lights, 12-24V, Canbus Error Free, 2000 Lumens Super Bright, 360-Degree Shine 90-EX Chipsets 3014 SMD LED: Back Up Lights - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: K&N Vent Air Filter/ Breather: High Performance, Premium, Washable, Replacement Engine Filter: Flange Diameter: 0.375 In, Filter Height: 1.75 In, Flange Length: 0.5 In, Shape: Breather, 62-1600RD: Automotive
Buy K&N Vent Air Filter/ Breather: High Performance, Premium, Washable, Replacement Engine Filter: Flange Diameter: 0.375 In, Filter Height: 1.75 In, Flange Length: 0.5 In, Shape: Breather, 62-1600RD: Air Filters - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: LINKITOM 40 LED Truck Tail Light Bar, Super Bright Tail Turn Signal Brake Reverse Tail Light with Iron Net Protection for 10-30 Volt Truck Boat Snowmobile Trailer Pickup RV Camper UTV UTE Vans : Automotive
Buy LINKITOM 40 LED Truck Tail Light Bar, Super Bright Tail Turn Signal Brake Reverse Tail Light with Iron Net Protection for 10-30 Volt Truck Boat Snowmobile Trailer Pickup RV Camper UTV UTE Vans: Tail Light Assemblies - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: Auto Ventshade [AVS] In-Channel Ventvisor | 2005 - 2020 Nissan Frontier, 2005 - 2022 Nissan Navara Crew Cab - Smoke, 4 pc. | 194407 : Automotive
Buy Auto Ventshade [AVS] In-Channel Ventvisor | 2005 - 2020 Nissan Frontier, 2005 - 2022 Nissan Navara Crew Cab - Smoke, 4 pc. | 194407: Side Window Wind Deflectors & Visors - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
DrawTite Hitch
Amazon.com: Tekonsha 118266 7-Way Tow Harness Wiring Package, Black : Automotive
Buy Tekonsha 118266 7-Way Tow Harness Wiring Package, Black: Wiring Harnesses - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: Hopkins 48470 Endurance Multi-Tow Vehicle Side Connector : Automotive
Buy Hopkins 48470 Endurance Multi-Tow Vehicle Side Connector: Wiring - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: Pop & Lock PL8450 Power Tailgate Lock for Nissan Frontier: Automotive
Buy Pop & Lock PL8450 Power Tailgate Lock for Nissan Frontier: Tailgate Locks - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
1.5
1.5" 6x4.5 Hubcentric Wheel Spacers | 12x1.25" Studs | 66.1mm Hub | Fits Nissan Frontier Pathfinder XTerra Suzuki Equator Specifications Vehicle Bolt Pattern: 6x4.5 Wheel Bolt Pattern: 6x4.5 Hub Bore: 66.1mm Thread Pitch: 12x1.25 Thickness: Each Spacer Measures 1.5" inches Thick Vehicle Fitments...
www.titanwheelaccessories.com
Interior:
Amazon.com: Dewhel Aluminum Silver Water Temp Meter Temperature Gauge Joint Pipe Radiator Sensor Adaptor Clamps 32mm: Automotive
Buy Dewhel Aluminum Silver Water Temp Meter Temperature Gauge Joint Pipe Radiator Sensor Adaptor Clamps 32mm: Coolant Temperature - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: ESUPPORT 5 Pin Way Car Auto Waterproof Electrical Connector Plug Socket Kit with Wire AWG Gauge Marine Pack of 5: Automotive
Buy ESUPPORT 5 Pin Way Car Auto Waterproof Electrical Connector Plug Socket Kit with Wire AWG Gauge Marine Pack of 5: Plug Connectors - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Audio & Comms:
Engine Bay:
Amazon.com: HELLA H84960111 8-Way Lateral Single Fuse Box: Automotive
Buy HELLA H84960111 8-Way Lateral Single Fuse Box: Fuse Boxes - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: 5 Pack - EPAuto 30/40 AMP Relay Harness Spdt 12V, 5-PIN SPDT Bosch Style: Automotive
Buy 5 Pack - EPAuto 30/40 AMP Relay Harness Spdt 12V, 5-PIN SPDT Bosch Style: Starter - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Hood lift struts
Suspension:
