1 - 2 of 2 Posts
you have to use stock nut. you'll be cutting at bolt head side so the nut will remain in tact. as far as uca sides, install sheet tell you which one is which. and also you cant mess them up because bump stop ends up on wrong side of the coil bucket if you use wrong uca.
hope this helps
1 - 2 of 2 Posts
