1 - 2 of 2 Posts
"06 , V6 2 WD. Has anybody replaced the PCV valve? How hard to get to it? I have 86,000 miles on my LE. I think it's time it should be cleaned or replaced ? I am still on my original brakes. Still lots of pad left.. I replaced original tires at 85,000 miles. It's been a GREAT truck !! Radiator is bypassed a long time ago. I have an extended trans pan installed. I do my own maintenance since new.. Thanx, Jerry.. ::smile::
· Super Moderator
I replaced mine some time ago. Tight area to work in but not too difficult to replace. The hardest part to me was removing the hose. Might as well replace the PCV hose when you replace the valve because it will be hard and close to brittle.
1 - 2 of 2 Posts
