121 - 140 of 152 Posts
Yes. Many, many parts. I'm the self proclaimed interchangable parts expert. What is it you are wanting to swap?
Sent by my R2D2 using Tapatalk
I was wondering about the 3.3 to a 3.5 engine swap As my husband is currently doing it but we are having some issues with the harness and ecu ...any more info on that maybe please we been working on this for a month now and kinda stuck...if u can message me back plz.
You definitely need the Harness and ECU from the donor vehicle. What you're trying to do will not work without them. I'm assuming the donor was an 01-04 Nissan Pathfinder or Infiniti QX4 on the R50 Frame being you need a real wheel drive 3.5
You may or may not need the Transmission too or some parts from the donor vehicle transmission.
Font Screenshot Terrestrial plant Multimedia Darkness
hi sir, could you please help me find what frames interchange with my 2002 desert runner king cab (132k mile). it rear-ended a truck on the interstate and bent the frame. thanks
A body shop with a frame rack might be the better option.
Sent from my SM-G975U using Tapatalk
I believe any V6 King Cab Frame will work from 99-04
[QUOTE = "TxDayTrader, publicación: 3843700, miembro: 89361"]
No podría decírselo con seguridad, creo que no, pero he oído que la transmisión aumentará. Pueden usar la misma transmisión pero idk. No estoy seguro de con qué problemas de cambio podría encontrarse también. El arnés de la transmisión también podría ser completamente diferente. Pinout diferente o simplemente arnés diferente todos juntos.
El 03 tiene el motor VQ35 y el 98 tiene el motor VG33
Según sTeVeXNYCPerformance en YouTube, el VG33 trans se montará hasta el VQ35. Entonces, cualquiera de las transmisiones debe montarse en cualquier motor.
[URL unfurl = "true"] V8 Engine swap. [/ URL]
[/CITA]
que caja sirve para vq35 de pathfinder? como para pasarlo a manual la caja de vg30 y vg 33 le sirven a la vq35?
What other cars use the same front rotors as a 2015 Nissan Juke?
2011-2017 Juke and 2017-2019 Sentra use the same brake rotors.
Desert Runner and 4x4 frames are different than 4x2 (non-Desert Runner) frames; they have a frame reinforcement where the front leaf spring mounts on the 4x4 and Desert Runner frames.
Ok thanks for clearing that up. I've heard what you've said (4x4 & Desert Runners being on same frame) and i've also heard that ALL v6 Frontiers are on the 4x4 frame. Guess the latter is wrong
Does anyone know if the 5spd manual transmission out of a 98 2wd frontier fit a 2001 frontier. I have an 01 and it has been rough trying to find a used trans for it but finally found one out of a 98 but don't know if they are compatible
I have a 2006 Nissan Pathfinder and I need of drivers side mirror and Can't seem to find a replacement for a decent price please help what other models will fit?
Rockauto.com has them in the $30-$50 range. There were several types, i.e. heated or non-heated or heated w/ memory. They come unpainted, though.
NISSANFRONTIER2005-2010
NISSANPATHFINDER2005-2012
NISSANXTERRA2005-2015
Question - will a 2007 Nissan Xterra engine drop into a 2006 Nissan Xterra no problem? Standard transmission on 2006. Need to replace engine but don't want to drop $2k on engine that won't tie in correctly. Thanks.
