Went ahead and added Utili-track rails to my SV non-value-package truck today. Installed the floor ones and the one at the front edge of the cab behind the bed.
The behind the cab one was easy. There are five fasteners. We ground the bedliner material off of the bolt heads and just bolted the junkyard-pull piece on with the fasteners that were supplied with it. Fasteners are stainless steel M8x1.25 with T40 heads. I did not have a torque specification so I got them pretty tight with a ratchet and the T40 socket, but I did not go crazy since my torx sockets are not exactly the best quality, got 'em when O'Reilly had just bought-out Checker and was clearancing Checker's tool inventory. When the junkyard pulled them they had to use a whole lot of force to break 'em loose.
The bed floor was not as easy. We took measurements and unfortunately most of the points through the floor where the OEM holes in the aluminum are line-up with structural sheet metal members under the bed floor. I suspect this was to make the attachment points stronger, but the net effect is that it's not practical to use most of the OEM holes.
As a solution we used the four knock-outs in the floor of the bed and to drill fresh holes in the aluminum tracks. Because of the bedliner I knocked them out from above, down to the floor. Had to cut the bedliner to free-up one of them. We selected some larger cut-washers and some larger carriage bolts with nuts that fit a 14mm socket, and some blue threadlocker. Even though the bolts are thicker and probably stronger we figured that only two attachment points probably wasn't adequate so we found one set of existing holes in the track where they did not line-up with a structural member (rearmost of the sets that are paired-up in the middle) and then drilled through the bed, painted the hole so it wouldn't readily rust, and then set more of the carriage bolts.
Once everything was snugged down and seemed to be in the right place we cranked on them by hand to make sure that the carriage bolts bit into the holes in the aluminum. Looks like they're in there pretty well.
I might want to add one more set at some point, haven't decided. We'll see if it's needed. If it is I'll have to decide if I drill fresh holes through both the aluminum and the bed, or if any of the existing holes in the aluminum can be used, just drilling through the bed itself.
