So I used the Custom Google Search here, and found zero results. I am just wondering how many have had this code and was it just the Canister Purge Valve, or does the light stay on even after replacing it? I already checked the gas cap but I did not think that was it anyway as I usually get a different warning message in the odometer. This time Engine light came on driving somewhat normally down the highway. Autozone has the part for $75.99 and it looks easy enough, I just do not want to get caught in the buy another part vortex.
2014 SV 39k miles, all regular maintenance done. Nothing else special about it.
You can find the updated-style of the canister vent control valve on Ebay in the $32 range.
So for now, disconnecting the battery for a while seemed to have fixed the issue. I had to clean leaves our of the gutters so I just disconnected it while I did that. No more light since then. I read somewhere this can happen if you leave the truck running while refueling, not sure if that is what caused it because I am guilty of that all the time. Hopefully that was the fix for me. It also cleared out old and unwanted radio stations as well.
