1 - 7 of 7 Posts
My 2011 Frontier V6 with 220,000 miles just thru a P0420 code (Catalysis below efficiency bank 1) Question: Should I just replace the down stream O2 sensor and see what happens or get it scanned with a scan tool? $$?
I don't understand you have the code "just thru a P0420 code" didn't you use a obdII reader already. You can give it a try replacing your O2 but with 220k Id start looking at your cat/s being clogged that's the below efficiency part
Yes, I have a reader, however, looking on the web for that code, it said that you need a "Scan Tool" ($9000) to tell if it's the O2 sensor or the cat converter going bad.
You do not need a high end scanner to read O2 data. Plenty of sub $200 code readers/scanners that will give live O2 data.
I believe it would be cheaper to just replace it.
if its the second set of o2 sensors, you should be able to toss extensions on it an call it a day. the secondaries are for emissions only, they dont change your fuel mapping.
Did you recently change your front O2. If not I would tend to think that your cats are dying. And if you want to go sensor route I would suggest change both.
1 - 7 of 7 Posts
