First time, long time! I am the unfortunate owner of a Frontier from hell and I can't tell you how much this forum has helped me repair my truck, I'm very familiar with the vehicle now and hoping to repair myself. Over the last few years I have done just about every "common" issue on my 2006 Frontier v6 4.0. This past weekend I was driving me vehicle when it suddenly shut off (this issue happened a few years ago to me as well and was fixed with a cam sensor). I got the truck a tow and when I got home gave it a scan, both codes P0340 and P0345 are coming up and the truck won't start, but will turn over and sounds like it wants to run... I can hear the fuel pump (haven't tested pressure), I replaced both camshaft sensors and still no luck. Through some research I have found it could be an issue with the IPDM? Any help is so greatly appreciated. Truck recently hit 160,000 miles.
Repairs I've done within the couple years
Camshaft sensor Bank 1 (within 50k miles)
Transmission rebuild (about 30k miles ago done at shop)
Cats (within 20k miles)
Timing Chain (within 10k)
Crankshaft sensor (within 10k)
Throttle Body (within 5k)
Plugs (within 10k)
Coil Packs (within 10k)
U-Joints (within 5k)
Drive Shaft Center Bearing (within 5k)
Camshaft sensor Bank 1 & 2 (0k miles)
Probably a bunch more but these are the ones that i remember that could be relevant to the problem.
Thank you for reading, any input is hugely appreciated.
Plugs (within 10k)
