Friday heading home my engine light came. Pulled over a few miles down the road and used scan gauge to check codes. P0171 & P0174. Also high idle. I checked as many hoses as i could today and sprayed flammable aerosol to check for any vacuum leaks. Removed and sprayed maf cleaner on sensor and after it dried reinstalled. Any guesses at what could be the issue? I've researched it and come up with dirty or bad maf sensor, o² sensor, vacuum leak and intake manifold gasket leak. Going home this afternoon it did sound a little bit like a loud injector noise or something. Only had noise when accelerating. Reminds me of 6L ford diesel.
Truck is a 2016 pro4x V6 53,••• miles.
Oh if it matters, it was sub zero last week and I've been letting it warm up a little longer than normal before driving. I can't stand driving cold vehicles, not just because of no cabin heat.
Thanks yall
Thanks yall
