01 Pathfinder V-6 AT. It gets hot while running down the road or idling. I took the T-stat off and checked it, opened fine and closed fine. Did a pressure test and no leaking. Pleanty of water, no smoke/steam out the tailpipe, newer fan clutch, no oil/water mixture on the dip stick or under the oil cap. The only thing I can think of is the radiator is clogged up. Your thoughts?
