Headunit Install
All the install gear that was needed for the head unit I found here on the forum, but there was one slight modification to the listed harnesses (see notes below).
Photo documentation may not be up to snuff but I will try to provide as much detail as I can and links to any of the helpful videos or posts I used as I installed. Sorry if you were hoping for guide with pictures to go with every step.
I began by tackling the wiring harness for the head unit. This was probably the most confusing part for me, but here is a diagram based on what I wired up. My harness was tot the neatest, but there looks like a decent amount of space in the dash. For anyone as confused as I was, here is a diagram. Please note I only included wires responsible for powering the unit, getting the backup camera working and keeping the steering wheel controls. I didn’t need the speakers wired since I will be installing the amp. Good luck and God speed on this one.
And here is the mess I managed to put together.
With the wiring all put together, it was time to take things apart the dash apart. For this I turned to Youtube and found this to be the most useful "https://www.youtube.com/watch?v=07cKDsQcx70". There are steps in this video that you do not need to follow so use your common sense and follow the steps as guide to removing the dash pieces and getting the stock radio out.
After getting the dash opened up I moved onto opening up the center console. It’s pretty straight forward; pull up on the cup holders and remove that section first. Then pull up and a bit back on the area around the shifter. At this point I fished the ends of my RCA’s, remote, extra USB through the dash where the radio used to be and down the center console.
I then mounted the radio to the dash piece, and then hooked the factory harnesses up to my spider web of harness and all the other connections. Then I fought to keep everything organized and fit back down in the dash.
Next it was onto getting the amplifier installed.
- Axxess ASWC-1 (Steering wheel control)
- Axxess AX-NIS24SWC-6V (Backup camera retention different from the one in the post by rlowery78 )
- Axxess AX-NISUSB-2 (retain the USB in the console)
- Vehicle Harness (replaces the recommended Metra 70-7552 that lacks the steering will control wires)
- Metra 40-N12 (Antenna adapter)
- Metra 95-7619 (Dash Kit)
