Found this on another Nissan forum... maybe this will help to end some of the negativity on this forum.
Nissan Frontier Forums: considering buying 2010 Pro 4x
x2 on that one.I wasn't aware that forum existed.
Wait.... did you just call an Astro van a truck?My last vehicle had a 4.3 vortec - AWD Astro. I never had any real problems with the drivetrain at all, it held together for 8 long years of pulling wierd off road situations (if you can believe it). I found the drivetrain to be fairly stong, but the peripherals of the ".truck" really weak. All window motors and door actuators had to be replaced, some twice, the security system failed during warrenty, not allowing me to start the truck, only if I sat in it for 10 minutes with the key in the ignition. Some very expensive sensors failed, causing me alot of grief. As for service, I would give GM a 4 out of 10. Too much negotiaton over stupid things.
Never again GM ... ever.
d-mo
for the other forum, you were at 85K or so and you consider distributor, wires, and tuneup routine? Maybe on a point type ignition.On the other hand, I don't have many complaints about any of the GM trucks I have owned. The engines and bodies last forever, and at least as far as longevity, if not performance, they have been as good as anything I've seen out there. During the 5yr warranty, I never had my truck in for anything other than routine maintenance, and this truck spent a lot of time off-road in really rough conditions. My main complaint was with the post warranty problems, that were relatively minor but really started to add up. Every time I turned around it was anywhere from 300-1000 for another repair. Some of it was stuff you'd expect like a tune-up, replacement of distributor, wires, etc., but there were many other not so routine repairs like fuel pump replacement, oil pan gasket, broken engine mount, leaking oil cooler, etc. Still, it's not stuff that I'd consider extraordinary, but with those kinds of repairs and more routine stuff coming up like brakes, shocks, tires, etc., it was just a good time for me to trade-in when I could still get some value out of it.
Vern
We should all be fortunate enough to see 220,000 miles. When it stopped what was the cause?My last GM truck was a 2500. It had 65K on the odo when I traded it in on my 2000 Nissan Frontier Desert Runner. It that 65K, it had the motor torn down TWICE, 38K and 52K. It was making "I'm about to break" noises from the THIRD air conditioning unit. My little DR had only a couple oil changes in it's life, and was used to haul 275 galons of water at a time across primative desert dirt roads in temps at times of 120+ degrees fahreheit. 220K later she stopped.
Nissans have there minor problems, fuel sending units, service engine soon light on, but the little suckers RUN.
:hick:
I think he said once it was an 05 4x4...We should all be fortunate enough to see 220,000 miles. When it stopped what was the cause?
haha amen to that, them little 3.3's aint got a lot of go but they'll go forever.My last GM truck was a 2500. It had 65K on the odo when I traded it in on my 2000 Nissan Frontier Desert Runner. It that 65K, it had the motor torn down TWICE, 38K and 52K. It was making "I'm about to break" noises from the THIRD air conditioning unit. My little DR had only a couple oil changes in it's life, and was used to haul 275 galons of water at a time across primative desert dirt roads in temps at times of 120+ degrees fahreheit. 220K later she stopped.
:hick:
As far as I know the issue with the timing chain was because some of the chains made it past QC with rough edges which caused the guides to wear prematurely, I don’t think it’s extremely common and I can’t recall any newer trucks with the issue. First I’ve heard about the radiator issue though. Both of these are pretty minor compared to the issues with the Colorado. A buddy of mine had one and the exhaust valve springs went bad on it and by the time good old bow tie had figured out the issue a year and a half latter and put a bulletin out on it his motor was shot and out of warranty at 65k so he was stuck with a truck with a blown motor, reminds me of the time I was driving and s10 and the trans just went on me out of no where with nothing more then two tires in the bed. Needless to say I hate Chevy , but to each their own, best of luck with the new truck it’s far from perfect and it will have it’s issues but I think you’ll enjoy it just fine.The Frontier's seem to maybe not have as many minor issues but to me the radiator leak and the tensioner issues are not trivial. What's even more unbelievable to me is that those issues were detected in the 05's, if not earlier, and at least for the tensioner issue, the bulletin still stands for my 2010. Before I even have mine, I'm hoping I at least have the issue before the warranty is up. Both of these are drivetrain problems, and I've never had a drivetrain issue with any GM truck. I'd consider drivetrain issues much more serious than any issue I ever had. Honestly, if I had the radiator/transmission issue it would have to be fixed under warranty, and with a lot better results than what I've seen most people getting, or I'd be done with Nissan for sure. On the other hand, I think complaints in forums are always misleading and my guess is this is nowhere near as common an issue as it seems (I'm hoping anyway). I can't tell you how many GM trucks I have been around with 100,000+ miles, and I've never considered the reliability of the powertrain an issue. The Nissan engine seemed a lot smoother and stronger than my old 4.3 V6 and better than the current I5 too. For me the GM just has an all-around feeling of inferior construction compared to the Nissan. It's always been kind of like having a very reliable 4x4 Yugo!
I currently own an 05 Crew cab 4x4, as you can see in the pic, I indeed owned a 2000 DR that I bought in late '99. My 05 now has 133K on it. Both trucks, AND the 04 Frontier between, had trouble with sending units and service engine soon lights. Before you make implications that someone is lying, maybe you should try to get your facts straight to begin with. All and all, I have owned a Datsun PU, the 2000 DR, an 04 Frontier XE, a 04 Xterra, and the 05 4x4 that had YOU confused.I think he said once it was an 05 4x4...
