1 - 10 of 10 Posts
Hello everyone. Installed this morning new optima red top battery, check engine light came up as soon as i started the truck. any suggestions??? is there a way to pull up codes without a reader?
thanks
Nick
ive never heard that there was a correct polarity for batteries for our trucks....even for the optmia's. as far as i know as long as you hook up pos to pos and neg to neg your good....
for the check engine light, take it to any autozone/kragen/pepboys and they should beable to read your codes for free.. (unless your in cali.... they stoped doing it)
Thats my question. Did the OP purchase the correct battery. After reading a bunch of these battery threads, a common thing has come up, the 2nd Frontier is opposite then other vehicles like GM. I am just asking to confirm the OP hooked it up correctly.
It is a good question thou, will a vehicle fire-up if the battery is installed backwards?
Discussion Starter #6
no you can not start the car with polarities reversed. the battery is installed correctly. cel comes on but there are no problems while driving or idleing. i drove around 50 miles today and have not noticed any problems. could it be a possible alternator problem???
If your alternator is not working, you will ultimately run the battery dead.
Try something simple. Disconnect the ground. Have a beer (15 minutes). Reconnect and see of the CEL clears.
that was my thought. just dissconnect and let the system reset. yes, putting in a new battery, it should have reset during the process, but it can't hurt and is easier then running out to check a code. if it comes back, then have it checked
:noworries:
Installed my Optima Red Top a month ago and no issues.
1 - 10 of 10 Posts
