Open door warning lights
182 views 1 reply 2 participants last post by  ForaFrank
#1 ·
'24 KCSV.
When cruising If I push outward lightly on the drivers door the overhead interior lights illuminate momentarily and the dash indicates an open drivers door. Same thing happens occasionally when going around a sharp right turn at a reasonable speed. Door is in fact latched securely. Door fit looks good.
I'm thinking there is an adjustment on the latch. Anyone able to provide a little adult supervision on addressing this issue?
Thanks in advance.
#2 ·
Hey @steel wheels, that's a strange issue with the door sensor triggering when you push on it or take a sharp turn. Have you had a chance to inspect the striker plate on the door jamb to see if it looks loose or misaligned? Sharing what you find there might help someone pinpoint the right adjustment for you.
Reactions: RobFrisco415
