hey all.. very long time reader, first time poster. north NJ area and I use my fronty dailying for construction and light hauling of the boat or tools.
have been dailying a CC long bed silver fronty for the past five ish years. started at 50k..and just about to eclipse 140.. besides tires and regular fluids, etc I think the most expensive or hardest thing I've had to do yet was buy a battery and replace Ujoints.
I've really taken to this truck, although I miss my fullsized, and really gotten to know it's mechanics like the Ford's and Chevys I own/Ed (worked on)throughout the years.
the other day I pull up to the job site and I'm smoking up front, so I figure that coolant is dropping on the motor and that's where my pungent smell is coming from as well. I've located it to this little cylinder where it has a cap and a coolant hose goes over the top but that cap is loose and it is dripping from there. In the picture the cylinder I am talking about is in the top third of the picture in the middle, right underneath the red wire. You can see the hose clamp holding the hose I referred to above. It looks like it also routes into the firewall and there is a metal three quarter inch line coming from another direction as well. does anybody have the name for this part so I can replace it? Is it easy? Anything else y'all know about this. I can't seem to find anything through my Googling but that's also because of my lack of information and keywords
the formatting may have rotated my pic:(
I had the same problem with my truck (2005) last summer. The piece that is leaking had completely disintegrated on me when I was trying to seal it up.
The part is called the heater outlet hose, or outlet heater hose, I've heard it called both.
As you saw, the whole part is the plastic bit that is leaking, along with the metal line that runs behind the engine around to the driver side of the vehicle.
The picture I attached has the part upside down, so hopefully it doesn't confuse you on the orientation.
It wasn't a tough fix, I believe it took about 15 minutes for me to swap it out. I paid $50 at the Nissan dealership for the part!
Hope this helps!
that may be it.... hmm wow thanks bud. it's the closest thing I've seen so far..I haven't seen the line connected to it in any pictures yet. researching the replacement of that part now to see if that's what I'm needing.
