Have you recheck the connection at the battery?
Why did you replace the battery?
The battery was dead initially because the positive terminal had corroded to nothing, and it had been sitting around doing nothing for over a month. I had the dealer replace the terminals and had them install a new battery. The battery seems to be fully charged and the connections are good.Have you recheck the connection at the battery?
Back to the dealer.
I also have the 6-speed and checked it out and it was that stupid rubber piece. Got it working Thanks for the tip!same thing happended to me... but im 6 spd. the little rubber gromet under the clutch wore out. which sends a signal to start it when clutch is pressed down.. $65.00
Have you checked your ground connection?Nuts. Bought a new battery and I still have the intermittent no start problem. Tried my other set of keys and it still did the no start thing.
I think I'll have to take it to Nissan and hope it fails at the Dealer. This could be a very expensive fix by the time every part in the book eventually gets thrown at my truck.
I noticed the second switch and guessed that it might be for cruise disengagement -- thanks for confirming that.2nd switch on the clutch pedal is for cruise control. ...
IPDM is pricey.
The clutch pedal interlock switch is fine -- I pulled it, connected it to a VOM and worked it a bunch of times. That was my first stop, but alas it wasn't at fault.Why don't yall just just cut the sensor off the wire and then spice the two wires together instead of paying Nissan 65 bucks? ...
