oil pressure on a z at idle is about 15psi and i would imagine ours would be the same. 60psi range in cruising and around 100psi if i remember from mine right at wot
Very cool. Thanks guys!
I ask because I'm contemplating adding a pre-oiler with an electric valve that allows the unit to charge once pressure reaches a certain point.
1 - 4 of 4 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
