I have a 2002 Frontier XE crew cab LB 4x4 with auto trans. About 2 months ago my truck started leaking oil. Location seems to be from either the front of the oil pan or maybe front main seal. The leak started becoming a bit more noticeable so this past weekend i decided to drop the oil pan. Well after removing everything needed to get the oil pan down I cleaned everything up and replaced the front and rear grove gaskets (felpro) and re sealed the edges of the pan with high temp ultra black silicone that came with the felpro gaskets. I then re installed everything else and dropped the truck back down. I let the truck sit for about 24 hours before I filled the pan with oil. I then let it run for several minutes to check for any leaks but saw nothing so i thought i was good to go. So then on tuesday I decided to drive the truck to work, but made 2 stops on the way 2.5 hour drive. First stop was about 30 minutes into the drive to get gas and i noticed 1 small dime size drop of oil under the truck after sitting for about 5 minutes. My original thought was that it was probably residual oil from before that dripped down. I did a real good job cleaning the engine and everything when I put everything back in but i thought there was possibly still a chance something could drip down from a spot I didnt get. My second stop was to grab a bite to eat and I was parked for about 20 minutes. i looked under the truck again and had a volley ball size oil spot under the truck so i checked the oil and of course it was low so i added some to it. I knew i couldnt drive it around all week so i drove back home (2 hrs) and parked the truck back in my shop.
My question is have any of you changed your oil pan gasket that can give me pointers on making a better seal. It amazes me that nissan from the factory does/did not use a full pan gasket and would use a 2 part sealing system. My guess is i did not get a good seal somehow on the pan even though i used the required amount of RTV and torque'd the pan bolts to spec. I have not had a chance to get under the truck to verify that it is infact the oil pan but with as bad as it all the sudden started leaking after changing it I believe it has to be the culprit. Really chaps my buns because I put about 11 total hours into removing and re installing everything by myself to have it still leaking and, at that, leaking WAY worse. Can someone give me some advice on creating a better seal for the oil pan gasket?? Or is there another area which from experience you feel the oil could be coming from???? Any help would be greatly appreciated. I only get to spend 2 days on the weekend with my wife and son so when i waste 11 hours of time "not fixing" something is really frustrating. Im pretty mechanically savvy so its not like I'm a nub like I said i removed everything on saturday in time for dinner with the fam, and re-installed everything in time to watch my Pats win the superbowl.
