Would using high quality oil additives for rattle at start-up be helpful?
Is your truck louder since you changed to synthetic oil?Would using high quality oil additives for rattle at start-up be helpful?
I second this response, my truck has never ran better. Mobile 1 0w-30 in mine alsoUse Mobil1 0W-30, not additives, and your troubles will disappear.
I get virtually no start-up rattle now.
actually before they can deny you warranty work they have to prove without a doubt that the cause of the problem is directly related to the use of synthetic oil. and they aren't too worried about synthetic oils per say its the changing of viscosity that they don't like since the motor was designed with specific weight oil in mind when it comes down to clearances. but anything that doesn't come on or in the truck from nissan isn't going to be recommended by them. i'm not saying 0w-30 is bad or good but if you think about whats really going on at start up simply changing oils isn't going to stop it. upon a cold start up there is a lack of oil in all the parts and there really isn't anything you can do to stop that from happening. if what your hearing is lasting more than a few seconds on startup then its something different going on, you may be hearing piston slap which lasts pretty much till the motor is warmed upI second this response, my truck has never ran better. Mobile 1 0w-30 in mine also
And every manual, for every car says they do not recommend synthetic oil except for manufacturers like BMW that put Mobile 1 in from the start. This is simply because of warranty purposes, if you put in synthetic oil and then try to get Nissan to pay for something that goes wrong they are not going to. People and vehicle manufacturers are still afraid of synthetic oils because it is still kind of a new concept, but the truth is that they run so much better on the synthetic.
CD2 indeed worked quite well quieting lifter noise in my old car, but I have one caution if CD2 is used on a high mileage engine. My old car had 200K Miles on it and CD2 unseated a lot of gunk. Luckly, I happened to change the engine oil within a week after the CD2 and the oil was black as tar and the filter nearly plugged. I doubt most of our Frontiers have enough mileage to make this a problem, but I thought I'd mention it.... I put in CD2 Oil Detergent (from AutoZone) and within a week the lifter knock was 100% gone. It has never come back. ...
I've always associated Shell's Rotella with diesel engines. Are you running a diesel or is this one engineered for gasoline engines too?I switched oil over to rotella t6 5w40 ...
Say what you want, but after about 20 years of using CD2 Oil Detergent I swear by the stuff!Oil additives are a bad thing. They are snake oil at best, and at worst will damage your engine.
Rattle at startup is (somewhat) due to oil draining back in the pan. That can be stopped (to an extent) with a decent oil filter that has a good drainback valve.
is this an synthetic oil???Use Mobil1 0W-30, not additives, and your troubles will disappear.
Shell rotella t 5w 40 is a good oil, do a seach for "bob the oil guy" I run this stuff in my VTX, and my ATV's.Shell rotella t 5w 40 is for all engines it has an sm api rating which our service manual says we can use in our trucks
