I'm starting to think my original idea isn't going to work out as planned, so post pictures of how you installed your switches so I can get some back up ideas.
I put mine in the sunglasses compartment as I don’t use sun glasses anyhow
Sent from my iPhone X using Tapatalk Pro![]()
very interesting but WOW expensive.Contra's set up is clean as other have used that space for switches and portable GPS devices.
I originally had switches in my overhead console by the Bluetooth mic, but since cleaned it up with Switch-Pros console. It reduces the need for additional relays and can be mounted anywhere, can be controlled via Bluetooth via an app and set up on or off-key. I went with the red backlighting since they started offering different backlight colors this year.
Pic below is pretty crappy and whitewashed out because I had my sunroof open but can get the idea.
Good luck in your search.
Firewall - comes with a mounting bracket.Where under the hood did you mount the other end of the Switch Pros unit? I'm planning to install one in the spring.
I removed the ruber pad under the ignition drilled a hole underneath and in ruber pad then replaced pad and installed switch. I could replace rubber pad with new if I ever wanted to go back to stock.
Correct me if I'm wrong, but you guys who did this to be able to revert by "just replacing the rubber pad", do you actually have a Nissan part number for just the pad? Because I've only seen a part number for the entire lower knee panel (which includes the pad). I have yet to see an OEM part number for just that rubber part.Looks familiar. Same line of logic too...easy to revert...
I was actually asking because I'd like to move my switches there too but not without a replacement rubber piece, was hoping someone had an actual part number I could look up ::smile::I could've sworn when I first installed the switches I had found just that rubber piece (my guess is it was eBay or something), but it's been a while since I looked into it as I honestly don't think I'll be reverting any time soon...every vehicle I've installed switches on has been in the same spot...just where I tend to prefer them.
Honestly wouldn't bother me if I had to replace the entire panel or just the rubber piece...
Ah, gotcha. Hmmm, let me do some digging. If I recall the last time I found it was by typing in the part number for the knee guard and "rubber" or something. Now you've peaked my curiosity. Lemme see what I can dig up...I was actually asking because I'd like to move my switches there too but not without a replacement rubber piece, was hoping someone had an actual part number I could look up ::smile::
the only stuff I found on eBay was the whole panel, makes me wonder if there's an actual part# stamped on the rubber pad - if there is, then it's got to be available separatelyAh, gotcha. Hmmm, let me do some digging. If I recall the last time I found it was by typing in the part number for the knee guard and "rubber" or something. Now you've peaked my curiosity. Lemme see what I can dig up...
Good thinking...I was going to pull that panel this weekend for a bit of wiring, I can double check that as well...the only stuff I found on eBay was the whole panel, makes me wonder if there's an actual part# stamped on the rubber pad - if there is, then it's got to be available separately
