1 - 20 of 20 Posts
I have provided everyone with the OEM Nissan part numbers and quantities for the parts that the Do-It-Yourself person can handle. I found it very hard to get a hold of the OEM part numbers that I found myself needing, so I put together a spreadsheet that has all of them in one place. These part numbers are for a 2005+ Nissan Nismo Frontier (2wd) CrewCab 4.0L V-6 Automatic Transmission. All of these part numbers are the same for both 2wd and 4wd.
I hope this can make your next mechanic job a little easier...
CPS
PART DESCRIPTION/NISSAN OEM PART #/QUANTITY NEEDED
  • Compressor 92600-EA31A (1)
  • Condenser 92100-EA500 (1)
  • Expansion Valve 92200-5Z010 (1)
  • Front Brake Pads 41060-ZP025 (1)
  • Front Hardware Kit 41080-EA026 (1)
  • Rear Brake Pads 44060-EA085 (1)
  • Rear Hardware Kit 44080-EA086 (1)
  • Front Rotor 40206-EA00A (2)
  • Rear Rotor 43206-EA010 (2)
  • Serp Belt 11720-EA200 (1)
  • Radiator Cap 21430-1P107 (1)
  • Reservoir Cap 21430-1P111 (1)
  • Fan Clutch 21082-EA200 (1)
  • Heater Core 27120-EA000 (1)
  • Lower Radiator Hose 21503-EA200 (1)
  • Upper Radiator Hose 21501-EA200 (1)
  • Rad Drain Plug 21440-50Y00 (1)
  • Rad Drain Plug Washer 21481-18000 (1)
  • Radiator 21460-ZL11A (1)
  • Thermostat 21200-31U1B (1)
  • Thermostat Gasket 13050-ZA000 (1)
  • Water Pump 21010-7Y00A (1)
  • Alternator 23100-EA20BR (1)
  • Starter 23300-EA20AR (1)
  • Oil Sending Unit 25070-CD00A (1)
  • Upper Intake Manifold Gasket 14032-EA200 (3)
  • Lower Intake Manifold Gasket 14035-8J101 (2)
  • Throttle Body Gasket 16175-EA200 (1)
  • Oil Drain Plug Gasket 11026-01M02 (1)
  • Front Shock Absorber (Offroad) 56110-EB025 (2)
  • Front Shock Absorber (non-Offroad) 56110-ZP025 (2)
  • Mass Air Flow Sensor 22680-7S000 (1)
  • Fuel Pump 17040-ZZ00A (1)
  • Fuel Pump O-Ring 17342-EA000 (1)
  • Fuel Level Sending Unit 25060-ZZ00A (1)
  • Fuel Injector 16600-7S00A (6)
  • Throttle Body 16119-7S001 (1)
  • Coolant Temp Sensor 22630-7Y000 (1)
  • Transmission Drain Plug Gasket 11026-01M02 (1)
  • Cabin Air Filter 999M1-VR006 (1)
  • Oil Filter 15208-9E000 (1)
  • Nismo Radiator Cap 21430-RS012 (1)
  • Nismo Cold Air Intake 16576-RND28 (1)
  • Nismo Exhaust System 20100-RS3D0 (1)
  • Nismo Header Set 14002-RND50 (1)
  • Exh Man Gasket 14036-EA200 (2)
  • Nismo Floor Mats (Crew Cab) 74902-RN3D1 (1)
  • Rear Shock Absorber (Offroad) 56200-EB085 (2)
  • Rear Shock Absorber (non-Offroad) 56200-ZP025 (2)
  • P/S Pump 49110-ZL80A (1)
  • Steering Rack 49001-ZP00A (1)
  • Air Filter 16546-7S000 (1)
  • Ignition Coil 22448-8J11C (6)
  • PCV Valve 11810-EA200 (1)
  • Spark Plug-Plat. 22401-5M015 (6)
  • VC Gasket (Left Hand) 13270-EA21A (1)
  • VC Gasket (Right Hand) 13270-EA20A (1)
  • Tailgate hinge right (upgraded) 93480-ZP00A (1)
  • Tailgate hinge left (upgraded) 93481-ZP00B (1)
  • Center support bearing 37520-ZL40A (1)
  • CAT Converter front left (4.0L) 208A3-EA21B (1)
  • Intake Manifold Plenum (ABS black plastic) 14010-EA200 (1) ***upgraded model***
  • Floor mat hold down clip 74985-4Z000 (1 for most, 3 on others)
· Senior Moderator
stuck.
changed the title to be more descriptive.
Thanks for the title help!
Sorry about the title, I just wanted to get this information out to everyone as soon as possible. I like the title you changed it to, fits better. Have a good day.
CPS
THANKS! I've been compiling OEM numbers & specs here & there on items I know I'll need eventually if I do work myself since I bought mine 8 months ago. I sure wish I'd stumbled on your work months ago.... Thank's again!
ZASH, no problem at all! That's is what ClubFrontier is all about, helping others fix and modify our trucks!
CPS
I appreciate the time and effort that CPS put into his list, it's extensive. In addition to his list, most if not all the part numbers for accessories and oem replacement parts are available in the online catalog found at Nissan USA E store. I buy most of my parts this way as you can usually get a 10-20% discount over walking in to the dealers part counter.
would you have any idea where i can find the nylon nuts for the hoot protector? 3 broke when i was trying to install it, and according to the dealership they nissan doesn't sell them separately. I've been searching like crazy and can't find the actual ones.
Discussion Starter · #15 ·
I added 6 more part numbers to my list, see last 6 part numbers on my list on page 1:
Tailgate hinge left
CAT converter front left
Intake manifold
Floor mat hold down clips
Enjoy,
CPS
Thought I would toss this site in there since Ive been looking for random parts.
www.nissanpartszone.com
Im sure you guys have come across it before but I was able to find part numbers for just about everything I needed for the new Frontier I bought. Prices are not that great but are less than retail and many can be found on RockAuto or eBay for a better price.
The only part I cant find yet is the female plug for the rear license plate lamp assemblies. Where the black and purple wires go into. For some reason the PO ripped it off and the wires are just hanging there, the LH side lamp is missing completely but it only comes with the lamp assembly and wiring harness/plug (male).
Here are some cosmetic items that I got part numbers for:
80960-EA300 Power Window Switch Bezel/Cover/Housing (Painted Silver from Nissan Pathfinder) - FRONT PASSENGER (RH)
80961-EA300 Power Window Switch Bezel/Cover/Housing (Painted Silver from Nissan Pathfinder) - FRONT DRIVER (LH)
Been hunting just this type of listing. Thanks for posting it.
1 - 20 of 20 Posts
