It’s fast and fun and at least mine is, so far I’m only getting about 18 mpg but hoping it improves a little after breaking in I only have about 400 miles on mine and it’s 4x4Someone mentioned the raptor having a plastic pan. Then I have no worries. Let it die already. For 50 more ponies and a manual shift mode, I'd take it in a heartbeat.
When's the last time a Glock hit a rock with the weight of a truck while moving? I have several polymer frame guns and not one needs a skid plate or 4WD. Just saying.Glocks have plastic frames that take a beating over and over. It is a cheap but good way to make a light frame. Not exactly classy like a pretty Beretta or 1911 but specialty plastics are working. The plastic pan is fine even though it isn't pretty aluminum.
Tt
Clint, I agree with you, I would not be off roading a new truck hard, They are too expensive now a days !!, No rock crawling with the new Frontier !I still don’t get who would take a new truck and beat the snot out of it? If I was to trail ride I’d buy an older rig and dedicate it so when it gets dented or disabled I still had transportation.
The funny thing is you always seem to see the brand new "offroad" trucks and jeeps hitting the trails within the first weekend or two after they purchase them.Clint, I agree with you, I would not be off roading a new truck hard, They are too expensive now a days !!, No rock crawling with the new Frontier !
I agree with you too, But those people have more money and less brains than I do 😂The funny thing is you always seem to see the brand new "offroad" trucks and jeeps hitting the trails within the first weekend or two after they purchase them.
That’s just several of the reasons I shopped around and found my low mileage 2018 CC SV.I sold my old Frontier with over 200,000 on it, it was a good truck, had its issues though. Well, I decided I would buy the 2020 midnight and hold on to as much of the old as possible. Big mistake so far. The transmission in this truck leaves little to be desired. Many times it can't seem to figure out what gear to be in. 1st and 2nd gear, so close and just slammy. Get a clunk at that forty miles per hour mark when adding some power. For the life of me , I can't figure why they went with this Daimler 9g tronic transmission. I mean, these are 4 wheel drive vehicles, Plastic transmission oil pan? Really. Don't even ask about changing the oil on it. Its PHD stuff with proprietary tools. You have to change the whole thing out by the way and its not too cheap either and then it has to be reset, dealer only option.
here's a true reply, one time during an arrest the glock .40 got ran over by an f250 and recieved light scratches only and it is still completely working, bushmaster is tough as wellWhen's the last time a Glock hit a rock with the weight of a truck while moving? I have several polymer frame guns and not one needs a skid plate or 4WD. Just saying.
hello goodwrnc3 I actually traded my 2018 silverado on a 2020 king cab and that 6 speed was a klunker for certain it did that since the day it was new, the truck however was quieter than my anything and so smooth but I hated that transmission this nissan 9 speed is a jewelI just purchased a 2020 Nissan Frontier Midnight, This truck is far better than the Honda Ridgeline and Silverado that I had previously, This Nissan is a simple truck, which I think is better, does not have all the systems that fail and are very expensive to repair, The drivability is far superior than the Chevrolet and Honda, So much smoother acceleration and shifting, and a much quieter ride at freeway speeds, If you stay in the throttle the Nissan shifts great, at slow speeds it can be clunky, but not as bad as the Chevrolet, I am very pleased with the Nissan Frontier, Not sure why any one would complain about having a Mercedes-Benz transmission, I think that is a good thing. maybe you should go drive the Chevrolet and see what a bad transmission really is.
Being run over and striking a rock on the trail are two different things. We're also comparing a pistol with metal bracing to a hollow pan. It's just not apples to apples. The gun has no bearing whatsoever to the durability of a plastic trans pan.here's a true reply, one time during an arrest the glock .40 got ran over by an f250 and recieved light scratches only and it is still completely working, bushmaster is tough as well
Want to add, they have been using these plastics on cars and trucks for years, and they are extremely durable. But not so much with trail style impacts. On a 2020 P4X the skids will do their job as well as they can. But on a lower trim without the plates, I'd rather have the stamped steel unit.Being run over and striking a rock on the trail are two different things. We're also comparing a pistol with metal bracing to a hollow pan. It's just not apples to apples. The gun has no bearing whatsoever to the durability of a plastic trans pan.
That's like saying you can microwave Tupperware so the pan will survive running through lava.
That's not correct.It's not a mercedes-benz transmission. JATCO purchased licensing rights to manufacteur a damiler-benz DESIGN. Nissan(Jatco) has their own model designation, and produces their version which contains some engineering and technology purchased from the German Co.
You're correct. I believe that the manufacturing end as to where and by who has to do with tariffs and taxes. As in much of the auto industry.That's not correct.
It's the Mercedes 9g-Tronic built in a Jatco plant. It's the identical transmission. Jatco, Renault-Nissan, and Mercedes have had joint ventures since 2010, and this transmission is one of them.
you are correct and glock is tougher than plastic for sure, I will never like my plastic pan but I dont truly think I personally will ever bust it, #1 it sits way up in the frame and even though it is a 4x4 I will never rock or cliffside crawl it unless there's a pot o gold up there then I am going! I basically farm a little and take my grandson to a deserted fishing lake that we now have to carry our stuff a mile back a rough azz place and im excited to drive to the waters edge and set up the tent truck bed style!Being run over and striking a rock on the trail are two different things. We're also comparing a pistol with metal bracing to a hollow pan. It's just not apples to apples. The gun has no bearing whatsoever to the durability of a plastic trans pan.
