1 - 3 of 3 Posts
Hi Guys,
My king cab Navara has been making a kind of grating noise from both front doors for the last while.Both doors still lock fine but its seriously annoying.I stripped one door today and it seems to be the motor in the unit that's making the sound, has anyone else come across this? Is it possible to open these units or do they have to be replaced? Thanks.
I had the same problem with mine, the driver side also sometimes wont open from inside, i got a newer door catch from a crashed navara and it sorted the problem and it sounds normal now, i had a quick look at it and true to nissan form it doesnt look like it is serviceable, If your motor is under warranty it will be covered, Its a bit fiddly to fit but not impossible, good luck
cheers
DM
Discussion Starter #3
Noisy central locking
Thanks for that, unfortunately it's out of warranty, apparently its a common problem with nissans, just have to look out for second hand ones,buying new from the local dealer's just out of the question.
:hi:
1 - 3 of 3 Posts
