1 - 4 of 4 Posts
hi peeps i have a bad noise comming form the pulleys. i replaced 7 months ago and the sound cameback
i know i know. they were from autozone, any brand you guys know it wont make noise?
i know is not the belt. is the damn pulleys
I assume you replaced the 2 idler pulleys/bearings? I had this same problem. It turned out it was my belts even though they looked new.
I replaced the bearings in the pulleys rather than replacing the entire pulley. Do the new pulleys align correctly? They might have slightly different dimensions than the stock nissan pulleys.
Also a possibility that your alternator bearing, p/s pump, w/p, or compressor clutch is making the noise. Did you try turning on the a/c to see if the sound went away?
1 - 4 of 4 Posts
