S.O.S...In need of 1st Gen.Guru's wisdom/advice?Bare with this above avg(B-)"shade tree",but enthusiastic,mechanic..I've owned my truck 5yrs. 35000mi.a"Toughluv $$ Pit"she's been,but...So sit your butt under my shade-tree relax...Recently i installed injectors,plugs&wires,fuel press.regulator,changed sc special 4oz.oil,all gaskets,all the vac.&coolant hoses behind sc,replaced any wiring as sought needed,all loom coverings,tore into sc spit shined it inside and out,pulled fuel rail cleaned re-installed with all new orings/insulators/spacers/nuts-bolts-washers,fuel filter,flushed and fuel tested before putting top half of sc back on,replace sc acqulator,entire distribultor with ignition coil and crankshaft pos.sensor(?) inside of distributor,IT'S MISSION ACCOMPLISHED???a Hail Mary,several cocktails and she turns over barley putputput stall again whawhaputtput vroom yes putt [email protected]#!XX#$$!...so i make certain by taking fuel line apart activate fuel pump air is dispelled to now steady fuel flow reassemble fuel intake,gas in the tank,battery is good,fuel pump good seems to me engine tuns over fuel air good but NO START!!!! IF NO SPARK WTF DO I DO PLEASE GURU'S LIFE LONG WISDOM IS SOUGHT AFTER S.O.S.
✌☮🍻🌴😎 Be good to yourself and enjoy the moment...jlaubach
