1 - 2 of 2 Posts
I have a 00 frontier truck ran great then one morning started up as usual turned it off for two min came back tried to start again and would just turn over but not start sounded like no fuel so replaced new fuel pump new fuel pressure regulator now trick starts bit after a few min it starts losing power under load put it on nutreal and truck slowly catches it self try to drive and it loses power then dies starts right up but no power then it dies again but this time won't start after a hour or so try to start truck an it starts up but repeats the problem again it also has a code saying bad misfire replace distributor assembly and gear ratio wrong and no data link to transmission then the usual o2 sensor problems have had truck for 5months everything great until this happened need help desperately
4 or 6 cyl? How many total miles?
When was the last time you replaced the distributor cap, rotor, wires & plugs?
1 - 2 of 2 Posts
