I was trying to set my ecm so I could check the timing for the first time. I got to ecm and saw that there was no screw to reset. There was a black plastic cover over the hole. I took the cover and did not see a screw. Well, I forgot to turn my truck and I stuck the screw driver in to see if the the screw was deeper inside. the idle shot up and drop. I turn the motor off. I took my truck to auto zone and see if there were any codes that may been cause by my mistake. she plug in the scanner and nothing happen. she said there was no power in the data link connecter under the dash. My truck run fine and everything seem to work, but I'm at lost. no power to DLC. anyone have any idea?. Need help on this one.
