I've got a 2000 Frontier with the 4
I've tried to hook up a obd11 meter to the port underneath the driver side (and so has Autozone) and the meter does not power up or do anything. I've got four wires going to the connector at the 2,4,5, and 9 pin positions (yes 9 and not 16). I'm not real good with the electrical stuff but I've found a couple of OBD11 wiring diagrams on line that indicate battery power should come from pin #16 ?; the diagrams also indicate pin 4 and 5 are grounds, and 2 is J1850 Bus+ (whatever that is?). Anyway, I checked everything and 4 and 5 ohm out as grounded to the chassis; pin #2 has 12 volts with the key on (although it also has a small ohm reading to chassis ?); however, no voltage or ground on pin #9
I've checked all the fuses (some with a meter others visually) and everything seems ok. Does anyone have any ideas? or does anyone have 2000 frontier that could look to see if their OBD11 connector is wired the same way?
Thanks
Thanks
