I was searching Nissan service bulletins for another issue and came across this one...
Classification:AT07-006a
Reference:NTB08-049a
Date:August 8, 2008
NISSAN; SPECIAL AUTOMATIC TRANSMISSION FLUID REQUIREMENT
This bulletin has been amended to apply to all current production models.
Please discard all earlier versions.
APPLIED VEHICLES: 2004 to current Nissan vehicles
SERVICE INFORMATION
If Warranty repairs are being done on a transmission listed in the chart on page 2, the listed fluid must be used. A claim to Nissan for warranty, service contract, or goodwill repairs to the transmissions listed below may be denied if Genuine Nissan ATF/CVT Fluid is not used as specified by the part number in this bulletin.
If Customer Pay service or repair of the transmissions listed below is done, the fluid type listed in the chart on page 2 must be used. Nissan recommends the Genuine Nissan ATF/CVT fluid part number listed below be used.
A/T DESCRIPTION__ FLUID TYPE_ FLUID DESCRIPTION___ PART #
CVT.................... NS2 (1) Nissan CVT Fluid NS-2______ 999MP-NS200P
4 SPD FWD.......... Matic D (2)... Nissan Matic D________ 999MP-AA100P
4 SPD RWD.......... Matic D (2)... Nissan Matic D________ 999MP-AA100P
5 SPD FWD.......... Matic K (2)... Nissan Matic K________ 999MP-MTK00P
5 SPD RWD.......... Matic S (2)... Nissan Matic S (3)_____ 999MP-MTS00P
......................... Matic J (2)... Nissan Matic J_________ 999MP-MTJ00P
NOTE: Nissan ATF/CVT Fluid and all chemicals are ordered through the Nissan Direct Ship Chemical Care Product Program: Phone 1.800.811.0502, Fax1.770.218.0148,
Website order link via dealer portal www.NNAnet.com or order directGenuine Nissan Automotive Chemicals.
(1) CAUTION: Use only Genuine NISSAN CVT Fluid NS-2. Do not mix with other fluids. Using transmission fluid other than Genuine NISSAN CVT Fluid NS-2 will damage the CVT transmission, which is not covered by the NISSAN new vehicle limited warranty.
(2) CAUTION: Use only the Genuine NISSAN Matic ATF specified here. Do not mix with other fluids. Using transmission fluid other than the Genuine NISSAN Matic ATF specified here or its equivalent may cause deterioration in drivability and automatic transmission durability, and may damage the automatic transmission, which is not covered by the NISSAN new vehicle limited warranty.
(3) Use Matic J if Matic S is not available.
Here it is.. NTBs/NTB08-049a.pdf
Date:August 8, 2008
SERVICE INFORMATION
