I bought a 2002 the other day and the stealership didn't fix the door locks or dome light. Talked to them and found that the deal was an "AS IS" deal. So tucked my tail and decided to try to fix the problem myself. Started with buying the repair book from the local Autozone to get a quick view of the schematics and see what and where the wires were connected to. Seems, according to the schematics, that the dome light is branched off the door lock power. I then checked the wire on the back of the fuse panel to see if it might have been cut or tapped for an aftermarket stereo. No luck there. I then noticed an area that the wires go to called a smart computer, if I remember right. It looks like the interface that the remotes talk to when you use your keyless entry. I am wondering if this box is what is causing all my problems, as I can't seem to find a broken wire yet??? Anyone her ever have this problem or had to replace that computer????
is it Nissan? or aftermarket branded?
check your fuses as well
99.9999999% sure that its the fuse, it may not look blown, but it could be (take a multimeter to it, it should not read open)
i have an 01 frontier and i'm kinda having the save issue over the last few days now my dome light works off and on and my door locks are goin wackey i have not got a chance to look at it yet tho
ok solved my problem!!! :) i had a speaker not working in the front passenger door my 01 has individual mini amps in each door and both passenger and drivers were pretty messed up after removing them and re-wiring them my dome light and door locks started working like new! 48hrs and no malfunctions yet:p
