Started with a 2016 P4X, 20k Miles, OEM Suspension.
FRONT:
2.0" In-Coil Spacer (advertised as no coil-bucket contact)
NISSTEC supplied Cam Bolts
REAR:
Single Add-A-Leaf
2.5 Degree Angle Shim
Retained Overload Spring in leaf stack
NO Aftermarket Blocks/Shackles
OPINION:
It looks and rides like it should have from the factory.
Rear rides better than OEM.
One bridge I travel across daily made the rear end rise and fall harshly.
Today the headlights held steady.
Attached snip of spreadsheet numbers "pre / post lift" and an image of the alignment spec.
Was hoping for more narrow toe-in, but it's within spec.
FRONT:
REAR:
Single Add-A-Leaf
OPINION:
